it stuck with broken hex wrench tip. tried magnet already but no good. since it is blocked by the hex wrench drill don’t work. I need like a carbide drill bit which is expensive.
I used this method but it was a M6 which was easier because it was bigger, maybe you will be able to find such a thing for whatever size the setscrew is.
I will try the remover. just drill bit won’t work I already tried. hex wrench is covering the set screw, and the wrench is titanium alloy so it doesn’t get drill easy.
That is good, you can try to heat the pulley up and drill the screw inside so that it falls out through the inner hole.
The heating up should help to loosen it a bit, the steel should ,as far as I know ,expand more than the titanium alloy.
yeah I’m afraid it stick really well. drill bit is grinded against tiatanium and I couldnt find tiny remover either it just too deep. I better off making a new hole and tap it.
Thanks for input everyone!
