Is there anyone that can make a couple of HTD5M 25 tooth pullies with 8mm bore for me?
25T is a non standard size… But custom tooth and bore… http://www.beltingonline.com/can-t-find-your-pulley-as-a-standard-7551
24T http://www.beltingonline.com/24-tooth-htd5-pulley-24-5m-15f-7779
26T http://www.beltingonline.com/26-tooth-htd5-pulley-26-5m-15f-7780
.unless you mean wheel pulleys…if you mean wheel pulleys I need to know who too for some 48 or 50T press in abecs…
I’m stupid, I meant 15 tooth but 25mm long. Motor pulley, I wanna run 2 belts on each wheel. It at least thinking about it.
dayum. 24mm belt?
Oh just goto the 25mm belt section on beltingonline…
http://www.beltingonline.com/15-tooth-htd5-pulley-15-5m-25f-7773
PS I’m running a 20mm belt on my next build…
pretty sure jenso runs 20mm belts on one of his boards. the resistance must be INSANE
No real reason other than I can. I just want to see how loose I can run a 15mm and 9mm belt on the same wheel and still have good contact and no slippage.
I looked at that, Mondo expensive to by 2 and have shipped to the US. I was hoping someone had some milled stock and could just cut me off 2 at 25mm.
Lol geez I was just thinking about 2*9mm on 20mm pulley
@mmaner btw 320-5-25 seems to be common on eBay and cheap15t 25mm pulley https://rover.ebay.com/rover/0/0/0?mpre=https%3A%2F%2Fwww.ebay.com%2Fulk%2Fitm%2F162579660375
I don’t know how I didn’t find that. Thanks brudda, 2 ordered.
Metroboards run 18mm belts and they sell a pulley but I think it’s 36 tooth
