Hello! I am attempting to build an electric skateboard but running into some issues with my duo hub motor
Heres the components:
- puiada duo hub motors
- Flipsky vx1 remote
- Tenka vesc
- 2 5s lipo batteries
When trying to use the motor setup wizard on my vesc tool, a “flux lunux detection error” message kept coming up. The other forums recommended checking the connection + soldering of the motor wires, but they all connect without touching. I finished the “input setup”, but the controller can only break and when I try to accelerate a whirling sound happens like the wheel is trying to spin but somethings off. This issue is the same in both hub motors. The first time I attempted to use the motor setup wizard the test did work, and the wheels moved, but they stopped working again when I tried to calibrate the forward vs reverse section. Now both calibrations dont work. Ive tried resetting the vesc tool, resetting the vesc, and switching the wire colors/ re-soldering without any luck. I currently am running sensorless since I don’t have a 5pin hall to 6pin connector, yet it worked sensorless the first time. The settings are currently in FOC mode. Any clue about what might be wrong?
Thanks sososo much in advance
