Hey guys, just finished up on my new build but still waiting for my hummie deck. I was trying out my board for a bit and noticed something really annoying in throttling.
When full blasting the throttle, my board refuses to accelerate or decelerate. Anyone know what the issue might be? I am runnign BLDC unsensored.
could have a sticky transmitter pot…? check in bldc tool to see the green bar. is the throttle staying up when you floor and let go it or does it come down when you let go and the motor keeps spinning?
Ill have to check… also my BMS is always warm/hot sometimes even when my board is off, I am running this set up bypassing discharge as well. Really not sure what’s going on with it
If your bms is hot when not riding and switched off then disconnect your battery immediately and check your wiring. Somethings wrong and could lead to thermal runway.
Yes from 0 to full within an instant, working on a fix and I will check if it’s just a small programming issue or something else. Will def update on it.
@dareno My balance leads were wired the wrong way. Have to redo the crimped pins on my balance lead housing. Simple fix!
The over current error happens only if I 0-100 (punching the gas) and it then doesn’t accelerate, but makes it idle until I’ve reset the throttle to the centre.
It flashes for a second on the faults when reading real time data but doesn’t fall under the actual faults log
