Collected my hummie deck and enclosure off of @bigben yesterday and I love it! Looks amazing!!!
I’m currently wondering where to mount the on/off switch, battery percentage reader and charging port. I love how slick and smooth the sides look so I’m thinking of putting them at the top.
Just wondering if anyone has done this on their build? Has it caused any issues (stones hitting on off switch, etc)?
I’ve got a android bt module (the one beginning with A? Akm? Or something) and I’ve not been able to set it up yet. Or at least when it’s plugged in and I load the app the information doesn’t display.
I’d like to have the display because I’ll find it easier.
I don’t have a Hummie deck, but people generally put the power button and charge ports close to the electronics. I like to put my switch and charge ports on opposite sides. I like these switches, they make the in different sizes, make sure you get one that fits the space your enclosure allows
I really don’t want to drill the side of the deck. It’s gonna have to be on the enclosure. I think I’ll put it in the very underside like you see on the enertion raptor board.
I want to get an LED power button but are they easy to wire up? When I got my on off switch I was told I needed a bulky harness to fit the LED switch?
And thank you @Sebike - I’m changing the wheels for Boa ones
You don’t need to use the harness, you can solder the wires directly with a steady hand. I don’t recommend having the meter on the bottom. It’s like a magnet for stones.
Push to start is cool. The only thing I don’t like about it is not knowing if the board is turned off or not. It would not be a fun day when you discover your board has been left on for an entire week.
@Mudders thank you. This is a replacement deck as my other one wasn’t long enough. The enclosure I made snapped as well. I currently have a single drive but I do plan to have a dual drive. Changing the wheels for some red 100mm Boa’s which will be fun on the 20-38t pulley setup!!
To all:
I’ve got a heat sink plate from 3D Servisas and its too wide for the enclosure. I have to cut the ends off of the plate in order to mount it.
My question is - what’s the maximum temperature for a FOCBOX before it becomes compromised? Do I actually need the heat sink plate? I know better cooling helps but do I honestly need it? I don’t want to cut a massive hole out if it’s not needed.
