fatboy from @Kug3lis
Are these still available? How much for shipping to Australia?
yea I will but donāt know the cost to ship there. Iāll post when they show and pm me and we can figure it out.
patience. theyre just making sure of things and then will do them all
Whatās the dimensions of the next batch? the electronics compartment
one deck with 145x 585 x 13 and other with two holes each hole 74mm x 585 x 13 with a 20mm beam between the holes
Both decks will be able to use the squeeze packs?
just the double hole deck.
I think I did the math wrong the last time, almost sure I had manage to fit 10S5P flat and 10S9P stacked, but itās 2 cell too short
Maybe 11S4P should fit
ive stared at ion cells and board thinking about it but I only glued lipo hard packs. 12s4p seems with the 6.6s seems challenging with wires and a bms and im just doing this part. bolting the cells down to the deck with other parts I designed and will 3d print and the compression foam iām sure i told you. And balance charge with a balance discharger (have to make a better one) and bulk charge fast to maybe only even just 4 a cell. I wont be able to go far and just slay whatās local. sitting around for half an hour or an hour at home charging is a nice break and itās pretty physical and nerve racking with the traffic. but if I wanted to go long late at night! which i do. Im waiting for a super charger. rather have a capacitor board could do a mile or two and then charge in a couple seconds and keep going the long distance. Yea thatās what Im working on next with tesla unhu. its not good but i always do nothing till everything is ready to be completed. when all the parts are here then its exciting and show you a pic after
I have a 10s5p in mine. Small Bms and loopkey.
Which bms are you using? And what vesc? I want to try and fit 10s5p and a double 6.6 flipsky vesc with bmsā¦
Its a teeny little bms that I picked up with a battery.
Lol Iām over here trying to stuff a 12s5p in thereā¦
Perhaps with one old 4ā¦ vesc sideways??
Focbox x2. But I have a separate heatsink cnc enclosur for them. Cut out will be all battery.
Nice, what vesc are you using? I may have to change the place of some things, dc-dc converter can go to the rear cutout since I will top mount the trucks
Iām my current board I use 150mm of length to fit the VESCās plus rest of eletronics
Focboxes.
Are in the way of MORE batterys
I get the feeling you plan on routing a large hole on your deck for them batteries if you havenāt already done so
Is that the pack you were talking about making?
