Just letting you know, DRV8301 and 8302 are not compatible.
Whatās inside of the ESCape? DRV8301?
https://www.mouser.com/productdetail/595-drv8301dcar
Did anyone else had this DRV fault?
Yup, SPI controlled.
I have messaged you.
Iāve filled out the form for the group buy, will payment and such be soon?
I donāt remember what quantity I filled out, Iāll take 2 with housing, should I resubmit form? I would also take an additional 2 single housings with PCB cover
What is ERPM and size of your motor?
I have dual 6374s 170KV motor from APS, my eRPM limit was left at 60000.
could be a simple silicone lottory faliure. hope you get this sorted. feels bad man.
It looks like you were well within limits. That sucks.
Vesc 6k limit is 150kā¦could it be a reason elsewhere?
I switched to BLDC mode, no more cutouts, evetything working perfect. Miss FOC a little bit just for launches.
Stewii sent me some procedures to pinpoint the issue but I still need to find time to open up the enclosure
Just finished my first oneā¦ some parts didnt come so I borrowed them from an old vescā¦while flashing the firmware there was smokeā¦sigh Iāll report back when my 2. iteration of parts arrivesā¦
Can you get a closeup of the DRV?
Is that flux or solder? It should really be cleaned up to properly inspect, solder balls floating around
And whatās going on here
To be honest this is the first smd soldering Iāve ever done. So its learning by doing so this was a 80$ lesson so farā¦
I have an inrunner 5000kv and tested it with a 3S battery (specs says 2S max) and got about 100k erpm. Here is a printscreen, top is BLDC and bottom FOC.
That will buff right out
