First the video
The loud soud is caused by the vibration of the motor, i dont know why the motor acts like that. It goes back and forth really quickly that causes the vibration.
First the video
Post info about your ESC and your battery setup
did you do proper throttle calibration?
Switch the wires around and see if that does anything. Re check soldered joints.
Also rebind your remote, could be a strange signal to the ESC
Thanks much, guys. Appriciate it
I found the problem. One of the phase wire was loose. I did check twice before i reached you guys.
Thanks again.
