That board rocks big time!
I would love to see it upgraded with a cheap battery from batteryhookup.com so you could ride it for days!
Great work for a young lad!
My only feedback would be regarding the pipe clamps, i think they may eventually come loose, so do be careful and check them each ride.
Maybe next you will try some welding? you could weld the axles for a stronger drive train.
Otherwise you could try to remove the steel axle in the rear truck, i think i recall someone did that on those trucks before. Then you can possibly insert the motor axle into the truck & use epoxy & set screws to fix it.
Overall great effort!
Thanks so much. The enclosure is just big enough to fit a screwdriver for the clamps.
