Do I need to re program scramboard vescs from original motors to my new motors or can I just replace and go…sorry kinda a noob at repairs new motors are 6374 149kv…old motors were 6380 250kv
You’ll need to set things up again. Run motor detection. What vesc is in the board?
Think they are maytec50amp v4.12
they may predate the 50A good on FOC version, it has a super-duper sticker over the Caps
Not sure I follow
Maybe an older version of maytech which don’t do 12s foc very well, newer ones have a sticker over the capacitors
opened up my board its a maytec super esc 50a will this sync up with my ordered motors which are turnigy 6374 149kv
and i plan on running this on my 10s4p battery. sorry for the most likely noob questions but i dont want to make mistakes or lose anymore ride time.
please be a YES!! i believe i did research this correctly …i think it should be ok…am i right?
You are right, 10s and foc not a problem. You could even go to 12s at some stage
Don’t forget to use the brass tube which came with the motor. You have to cut it exactly to fill 100% of the gap between motor bearing (6mm below the motor plate) and pulley. It is necessary because the SK8 motor has no circlip to secure the bell and shaft.
According to FOC if it doesn’t work with your esc you can accelerate but can’t brake (cut off) so don’t go downhill, test it at home first time.
Awww ya. Great news thank you. I will maybe have a vesc program question or two I assume. Also got a Bt chip from flipsky since I was already gonna be doing surgery. And installed a USB extension port from vesc to exterior of casing.to make it easier to get to instead of opening up everything .When I receive motors I will post the issues if any. This has been very helpful thank you again.
hey i have some vesc programming questions…motors are installed…i set up to my pc…vescs are connected and shows in vesc tool. i did the wizards and they seem to work and save…but motors arent reacting consistantly…i think i just need someone with a clue to tell me what ive missed here…can u help please…
