I really need advice on what to do with this motor mount situation. I have build a board around the Turnigy 6374 motor. I can not get it to sit reliably on the trucks.
I have used the board for maybe 5 km og riding and on each ride, the motor mount came loose. I have tried to fix it with some steel epoxy. But it does not seem to work.
The mount is a cheap shit chinese mount, which i will never buy again.
I have bought a set up Hobbyking longboard trucks and is waiting for the hobbyking mount, which i have heard is quite good for the price.
But i did not see that the trucks does not fit into the 2cm hole in the pulley.
My question is now.
return the Hobbyking trucks and try to find a way to weld the mount to the paris trucks? (i have no experience with welding, but i have access to a welder)
keep the Hobbyking truck and mount and then try to cut down the edges of the truck so it can fit. (its 22mm diagonal)
should i find a diffrent mount or pulley for either Hobbyking trucks or paris if so what?
get a drill, put the hobby king truck hanger in the drill. pin the trigger down and put a file to the outer edge of the hanger until the pully can fit over it.
you only need to file down just enough for the pulley.
I had the same problem when using that motor mount. I solved it by buying longer set-screws and then adding a slim nut. This way, the set-screws are locked down from both the threads within the motor mount, and the nut. The motor mount never came loose again after I did this. Also use lots of loctite!
The hk trucks are caliber clones, so you can get a caliber motor mount. I would recomend the diye one on amazon, because it is a decent affordable solution. You cam get pulleys for relitively cheap, so if you go with that aproach, it should not cost mcuh
