I am trying to build my DIY electric mountainboard I bought most of things and I did list about what I bought. Now I have to buy or build batteries. If I will build my batteries, I will use 18650 10S4P but if I want to buy batteries, how much C I need?
I’m a bigger guys at 240 lbs so I opted to go with 20700B batteries. I think it ultimately depends on your needs. I needed something that help my fat ass get up some hills. Keep in mind that 20700B’s are more expensive than lets say the 18650 30Q’s. So they’re not necessarily practical for budget minded builds.
I’m not sure actually. I thought Sanyo was the only company making them. They say they are 4000mah batteries but they all measure 4250mah. The information out there is a little bit confusing about it. Needless to say I digress since I’m not the builder of the battery. @Kaly is building my battery, enclosure etc… he’d be able to clarify things. My battery should be ready around the first of October right around the same time my Kaly gear drives will be in I can’t wait.
all things considerd i dont see a real benefit in sanyo 20700B, for the pricetag that you can get them. In the end your riding style, terrain and body weight are more important for what type battery you need. Since i assume you live in Turkey it is probably quite hilly with fked up streets, sorchiing summers and rainy and cold winter.
The good thing about a mountainboard is that you have a ton of space on top for a weather sealed box, so you can make a big battery and actually have a wider range of choice for your battery.
