This is just a plastic model. The water proof aluminum box is really sold later. We also added a fireproof switch to esc6. contact me if you want order please.
What QC-testing is done? Is the NRF included with the PCB antenna? How does Warranty work? How do you support Ben Vedder in relation to sales?
I just received the pics of the aluminum case it’ll be housed in, and I’m a bit confused as to its size. This VESC on its own looks smaller than any of the other HW 6 VESC, but the case is like 100mm x 90mm or similar.
Now one thing I am quite curious about is will you be making a dual VESC 6, or at least a dual case for this VESC? I plan on running 2 VESC’s, but if I was to go with this unit, it seems odd that I would have to have two power on/off switches… Also, is there a way to mount the buttons on the enclosure so I don’t have to open the enclosure to turn the system on? Or could I simply just leave them in the ‘on’ position, and add a anti-spark on/off switch further up towards the battery like a normal setup, and when that is turned on or off, the VESC’s, being left in the ‘on’ setting, would turn on or off automatically, when the other switch is turned on or off?
