I realize most of y’all don’t know me,
so I don;t expect y’all to place much value on my ESC recommendation.
So, If you are in the Atlanta area, and want to try it on your kit,
hit me up and I’ll meet you and let you take it for a spin.
A Graupner ESC with a Turnigy SK3 192KV motor and a 10S battery is a whole lot of power.
I put it with a 3000 Watt hub motor from that miami boards cat ,
and it rides like a damn Cadillac
, it even makes a muffled gurgled beep, like a flying car on the Jetsons.
It you’re around the ATL and want to try my Graupner ESC, let me know.
Which advantage this one should have over a vesc based esc like this for example
It’s about the same price, at the moment as group buy even more cheap with 120$.
If I have seen right in your esc is a build in BEC which would enable us to add lights, horn etc. up to 8V. Is this right?
I’ve had five VESC type ESCs,
I find the Graupner to be more responsive accelerating
and very similar in braking.
I use my Graupner on the lowest settings for torque and acceleration.
