Ah…ok. If it is the canbus chips then you won’t see any benefit until they’re removed…I’d get someone to assist with this if you’re unsure. I’m in Oz otherwise I’d help.
Are they hard to remove? I just break off the joints at which they’re soldered?
Nah that’s not it nor tin
i don’t see any order of the cables, looks they’re just thrown in there and glued.
don’t want to attack you or kaly but yeah, thats just my 2 cents…
It isn’t one of Kaly’s builds Dan, neither of Jinvy’s urban carvers are… for some reason Jinvy just keeps calling them a “Kaly”?
ah now i get it, this explains it. if i would go commercial and my wiring would look like this, now wonder it’ll fail at some time.
yet, this is still some super bad wiring work.
it’s a bit of a mess alright…to get this thing working again, you need to take out the VESCs anyway. Just remove the cheap glue and get that shit out of the enclosure.
Relatively certain you get it all working again if you send it in for VESC repair. I would not recommend just removing the canbus chip, since this is VESC 6. Split ppm will supposedly cause issues. Only alternative to that which will not cause issues is running with dual receivers.
Makes no sense for us to try and make sense of the wire & glue mess.
My wirings are even worst than this , I feel bad !
Its a HW 4.12 at heart, and that is why the CAN chip blows when connecting only one ESC. A SIX would not have had any issue.
misread & was confused due to X (i guess this is in older focbox).
If this thing is 4.12, the canbus chip can be removed and you can run split ppm for a cheap fix.
Ahhaaaaaaa that makes sense! I saw a video of Kaly building a board a week or so ago and the inside was even more beautiful than the outisde (if that’s even possible!).
Look at those packs
NOTE: I’m putting this here so people do not confuse a true @Kaly build with a build made out of Kaly parts. I mean no disrespect to the original builder, but the majority of us build boards with good parts and do our very best. And then there are those who create true works of art that we ride. Kaly is one of those people and his work shouldn’t be confused with that of a mere mortal.
Canbus chips fried. Done it myself
If canbus is causing so much problems why do people insist of using it? Split ppm is far more reliable…
I also fried a vesc using canbus for no reason.
You’ve either blown the can bus or the stm chip. Remove the can bus or replace the stm. In case of the stm you most likely have a short on the 5v rail.
it is stupid to not use canbus, it should NOT fail
The meaning of kaly is beautiful
Oh yeah!! Just looked it up. An extremely apt name
