I finally successfully build my board (build log coming soon), and built the confidence to go full throttle (On a previous version w/ different motors I fell off at 26mph). I found myself wanting more… How can I do that on the cheap? An esk8 calculator said I should be getting 22mph loaded but it certainly doesn’t feel like that.
Current specs are:
KEDA 6364 190kv motor
Enertion 4.12 vesc
2.25 gear ratio
90mm wheels
8s1p 20c 5000mah lipo pack
In the near future, it will be a dual setup with another of the same motor.
The cheapest ways I can think would be to get a 2s lipo with the same specs in order to kick the overall up to 10s. Next cheapest would be wheels. I don’t want to sacrifice torque, otherwise I would adjust the gearing.
I also have a couple 5055 280kv motors sitting around. I could do an uneven dual drive as tested by @lowGuido.
Anything you do to speed this board up without adding more power will result in a loss of torque except upgrading to a 12s pack. With your set-up, a 12s pack will get you to 30mph
well, I can see myself drifting off to the side or losing traction on 1 motor, slow breaking guaranteed too.
I just know its bad but I don’t want to say something I don’t fully understand.
There could be belt slips more stress on pully maybe more heat on motor from a big load.
I would argue that it depends on the esc. I’ve hit the brakes at 30 with 10s, a 6374, and 3d printed pneumatics on California pavement and been totally fine. Given, I run an ESCape which seems to know just the right curve to get me to a stop as quickly and smoothly as possible.
To stay on topic - the higher the voltage, the better. Just make sure that your ESC can take it.
