Update the last ride in deep snow:
First impression of the MBS F5 bindings are super. Feel way much more locked with them. First impression of the MBS 9" wheels… they definitly rock da house… super good grip even on snow. didn´t expact that.
As usual not everything went well on by ride. I got suck once in deep snow and was wondering why. Realised that the XT90s on the back ESCape box became lose a bit and the VESCs throttled down the power output. The problem caused the very tight cable length and that I fixed the cable on the bindings. I´ll probably just add a adapter xt90 which will give me like 5cm more length and everything should work than in future without issues.
Unforunatelly that was not the only fault… Short after that I noticed some kind so scratch noice comming out of the front. Very quickly I realised that something with one of the motors went wrong, so I tried t come home as fast as possible. At home one motor already didn´t moved at all anymore, so I took the motor appart and found one borke magnet there… As this was the last opportunity for me to drive this year I decided to take the second board and continue driving… Eveything was fine for the first 15km… after that the same thing happened… so in total I broke two magnet on two motors and both of my boards… That´s not how i expacted the year to end. I can´t explain the broken magnets as they didn´t got hot etc. but I now definitly know that it happend while i had bad contact with the road and the wheels where spinning up on a high rpm.
If somebody can explain me what could cause the broken magnets I would be very happy.
That´s already the 3rd bell from this motors with this issue. I still worry a bit that this can happen one day when I drive on top speed… motor locks up and I, with bindings, locked to a 25kg board
So what´s my plans now… I´ll get two replacement bells for the broken two. That will happen only in January, so till middle of February my quad is definitly out of work I already started to battle harden the motors which still working. That means I fill the empty space between the magnets and the bell with epoxy. I hope that will give them more strengh and it was the last broken magent on this motors. Honestly I would like to swap the motors to maytech or similar after that experience, but to swap out 6 motors is not really a cheap thing and than you also don´t know if it will maybe happen with the new once too.
Here one picture how I get my boards dry after a snow ride
And even if i hadn´t too much driving time, I tried to make some small videos
