Hi i am looking for a 12s4p battery any good links? need to run vesc6 and torque motor 190kv.Or any other high quality battery.
Thank you
Thank you
Would like to make it run min 20 miles range
this again?
cheap isn’t a number.
What is your budgeted amount for a battery?
300-475 is my budget some place in there
$450 With Samsung 30Q cells
products/electric-skateboard-battery-epower-pack-12s4p
Im buidling an E-MTB wont fit inbetween my feet or under the board its to long… i need a cube ish
Have you considered using Lipos? A custom battery might be over budget
yes but a 2x 6s 5600mah 60c isnt gonna last me even close to 20 miles
You would need 4 of them. There is another source let me see if I can dig up a link
the motors i have can only handle 12s…
is that a 6s?
go with lipos! hobbyking has quite alot over 6s +10000mah ones.
also, range is a matter of driving style!
Yes, 2 of these would give loads of power and maybe get you close to 20 miles depending on gearing, rider weight and if your climbing steep hills or not
not with over 20c rating
Higher C rating means less voltage sag which increases range
yes i know its just achmed was saying 10000mah on hobbyking but they all have 15c witch is bad
sir, you want to do some math first! 20c x * 10000mah = 200 amps and thats not even including burst. a single motor wont handle more then 80 amps usualy
