Wiring show below via simple photo-shopped file, sorry if its not clean looking this was the easiest way for me to visualize it.
Anyways to the design!
A123 26650 batteries in a 6s5p config. I am going to get this built by @psychotiller (if its approved) but I just want to make sure my understanding of how battery packs are wired is right.
DieBieMS - connections via molex and input power from batteries
Output to female xt60, then goes into a male xt60 to dual female xt60 output
FocBox male xt60 input
10 inch wide hub motor; 24v input, 600W power
Another xt60 splitter (one for usb charging, the other output for future led lighting)
Step down converter to dual usb charging ports (input 8-22v, output to 5v)
Barrel connector
Boosted board charger (outputs 100-240v, 50-60hz) I figured it would work as boosted uses the same cells.
Any input is appreciated! My few concerns are if the pack can properly power the motor, I calculate it will output about 20V so I hope undervolting a 24V motor is okay.
Fuse won’t help with anything unless it’s a short circuit…
Getting a proper charger is not expensive.
Just sayin if that diebiems is not configured properly or it it does not cut off charge than the boosted charger will charge your 21.9v pack to 43.8v which =
