[Inactive] Vesc android/iOS app
I want to help too. I already wrote you a pm :wink:
today i added a way of controlling the vesc via the data log page.
its just a basic slider and i might add more functions later, but for know it makes the vesc think that it is getting nunchuk values so we get the benefit of ramping. i was testing it today with @onloop it has a few bugs with the slider but that was all so complicated but is now fixed.
i will hopefully add a video very soon, Iā€™m fixing some bugs that need to be fixed before i share the app with better testers
Like i said, i am actually a Software Developer. Maybe i can help you fixing the bugs?
ok then, i just want to get it finished my self as i have been working on this for over a year now, and asked for help back then and didnā€™t get any, now that i am not very long away from finishing i have had a lot of ppl asking for the source code, i just donā€™t want to loose the time and money i have put into this before i even get to release it.
i also donā€™t want to hurt any one because i have missed some thing.
Super excited to see this come out!
yep, iā€™m up for this. I PMed my deets as well. Very excited to see data and do configs on my phone, especially while out riding. Iā€™m planning to order the BT board this week if nothing wonderful happens.
Well, i will try to find the right ports on the connector myself but it would be good to see the wiring of the hm-10 module and the vesc uart plug.
on the bottom of the vesc if you look next to the pins there will be little labels.
we want to use the RX,TX,VCC,GRD
basically its the same on the module but you swap the RX and TX so RX on the vesc goes to TX on the module, and TX on the vesc goes to RX on the module.
@DeathCookies i have sent you emails with a custom firmware for the version 4.10 vesc to allow write config and the latest .apk
but i have made a lot of ui fixes since i last sent you the .apk and i will send u another one tonight.
Yeah, i already connected it like this way and setted ā€œApp Configurationā€ to use PPM (Receiver) and UART (HM-10). Also the Baudrate to 9600 but the i cannot find the hm-10 module in the app. My apporach: app --> settings --> scan --> it found nothingā€¦
Also i have a wrong firmwareā€¦ when i install your firmware the bldc tool says 4.16 but i need 4.15 for my vesc.
why do you need 4.15 for your vesc? 4.16 is the latest firmware version.
also there night be a few things that could be making it not find it, like your bluetooth is turned off in your phone settings.
or you module is set for master instead of slave.
or the SDK that i used for the building of the app
il have a look and can you please have a look
there is an app on the android app store called BLE Scanner, if you download that and just see that you can find the module and if you can the connect and send me a screen shot of what it shows
Now i got it sorted. It is working well. I wrote you a list of bugs i discovered :wink:
Hey Jacob, I sent my UDID and board is on itā€™s way.
Alā€¦
The new VESC PHONE APP got a Big Mention & Demo in my last VLOG. Check it.
Looks awesome! Will the released version of this require a similar Bluetooth devise to be plugged into VESC?
check out my video guys @onloop you will like this!
Any plans on adding Android Wear support? Would be sick to have real time info on the wrist. Willing to help/build it as soon as I get my frickin board actually running as it should.
I would like the apk file. Iā€™m wondering why you have not uploaded it to github?
So I have the app and a Everton 4.12 vest how do I link the two?
