Hello everybody.
My name is Fulvio, I’m new here and new to electric skateboards.
I recently bought a prebuilt chinese rebranded board called xskate27. I did it because of i had the opportunity to pay it monthly.
Now. Its maximum speed when i hit plain streets is acceptable but when I have to climb streets with inclinations the speed slows down drastically. It can’t push me properly and mantain a decent speed. I’m 91kgs.
I disassembled the board in order to ask for help and suggestions (I attached a few pics)
Before posting here i tried to study a little bit.
The board has an integrated radio controller in the esc and the esc itself is one for two motors, has a specular design and a servo connector.
It mounts 2 250w motors (i could not find a label on them)
I’m quite sure they do not run at their maximum capacity and i feel quite frustrated by this.
Now my questions are:
How can I improve the maximum speed?
Have I to buy new escs and a radio controller? Which?
Can i modify my actual esc by replacing capacitors or other components of the circuit by increasing its voltage output? Will work?
What about the battery pack and its power? Can it allow an higher speed?
Hi, I recently made a new battery pack for a BenchWheel dual. I kept the same configuration 6s4p but used newer Samsung 30q cells. Without changing anything else every area of performance was improved, especially climbing.
looks like a swagboard…
its a low cost board. with hubs. you should be happy if it can take hills at all…
you could try upgrading the esc and battery to 10s.
but its the upgrade is going to end up costing more than the board itself…
As simple as change to VESC, get new battery pack.
Technically all of the above is needed to increase the voltage of your electrical system. Increasing voltage is currently the easiest practice to increase speed.
and found a 10% discount code online. The next decisions you’ll need to make is to solder or spot weld. I went down the spot welding path using pure nickel strips. Excluding the spot welder I think it cost around £120 in total. Because I haven’t changed the battery configuration and the voltage is the same the existing BMC, controllers & motors work fine.
I think 'll start with the esc. Then move to the batteries and then to the motors. Lol. A new board.
I found this battery pack www.ebay.it/itm/222448125461
Don´t use that pack. It´s only a 10s2p and lacks on capacity. Get at least a 10s3p, or better a 10s4p to avoid voltage sags and short life cycles of your pack. Otherwise you have to buy a new pack in a few months
Whats your budget? Getting good quality on 18650 seems to me to make or break the whole battery, also better battery -> less heat loss -> more fun riding/less wear/better lifetime…
Also look at this, that pack does not state the actual cell used. Even comparing two cells from the same brand there can be huge differences!
And this is only for 7A, because the red cell does not have a curve for higher currents, probably due to too bad performance. A drop of 0,6v(this is the difference between the good and bad cells, and is dropped inside the battery under heavy load) versus another better cell will make a big difference in performance. Probably 20% in top speed and maybe 40 % in power. And i mean, 7Amps shown here is not alot, you have 2 cells in parallell so each would only see 3,5 in this example but i can easy draw 70 amps on my board, im even a bit lighter than you still.
Does your current battery get warm after heavy use? for example if you draw 10 amps from a cell and the output drops 0.5 volts during the draw, thats 5 W(amps x volts = power) of heat generated in that cell. for your battery with 7s2p that would total 70w of heat applied in the battery… this would also land you at an output power of around 400-450w… with close to 20% energy being wasted to heat in the batteries alone!
easiest solution is two 5s lipos in series. Or, to have the pack slimmer, 5x 2s lipos in series.
Otherwise get a pack made from one of the vendors here, but that is gonna throw you in the 300 bucks region.
