Got it. It is the quickest solution. What about 2 of these in series?
Putting two 10s2p in series gives you 20s2p, which is not ridable. If you put them in parallel, you get a 10s4p, but a much weaker one than you´d get with lipos or proper liion 18650 cells.
Why not ridable? What about two of these in series? Guardalo su eBay http://www.ebay.de/itm/401247775451
Do a bit more reading here before you buy anything twice. We normally build boards from 6s to 12s, because of the availability of parts and the needed power for our purpose.
I can´t tell you about that brand, but I would take these: https://hobbyking.com/en_us/turnigy-nano-tech-5000mah-5s-35-70c-lipo-pack.html Better and cheaper. 2 in series.
Got it. Thanks so much for the help and patience.
An additional question: Will I burn or damage my actual esc if I connect to it a 36v battery pack? What have i to expect if it is set for a lower voltage?
you´ll have some fireworks, smoke, or if it is really boring only a +bitch+ and your esc is gone Would be too easy if you could hook everything to a 6s esc
I put a 18v drill battery (1300mah) in series with my actual 24v to test and it worked; my esc and motors support up to 36v. The board speed increased by 70%. There are no speed limeters on the esc. My battery is simply low voltage for the system. So with 2 good 18v pack I’ll be ok. @TarzanHBK
If the Esc support that higher Voltage, you´re good to go
wow, thats impressive. great that it seems to work!
is this any good?
