Hi everyone,
I need a bit of advice building a 12s setup with a focbox.
I’m concerned about an inductance issue that might occur due to the length of the wires.
I read that I should avoid cables longer than 30cm,
But in my case there is only one polarity which has to be quite long ( 50cm).
Also it worth mentioning that I’m using large flat copper tape, 5cm by 0.065mm thickness.
And I know using flat cables next to one another will prevent huge inductance.
Still, what do you guys think about that?
Thanks for you inputs
- Inductance does not discriminate when it comes to polarity so I dont thing that is relevant.
- All the copper inlaid boosted inspired people use wires that are longer than 50cm and I have not heard of any problems so far.
I built a Boosted clone with fairly long wires, and I have never had a problem. They seem to have more influence when running FOC, and I’m currently upgrading it to FOC, so we’ll see.
Thats what im afraid of. I also have a boosted like board and the thing ran perfectly fine on bldc with 4.12 vesc. I switched to FOC and all of a sudden the vesc was overheating. I’ll report back when i test it with FOCBOX.
I didn’t do the math but thickness of the wire effects the inductance too what size equivalent cylindrical wire would you be using?
I’ve never incounterd that problem with my 4wd and it’s a 39inch deck and from one end to another running foc with no problem but I think this because am using 10awg
Did you ran 4.12 vescs at any point? I’m also using 10 awg.
Am running 4x focbox With 10awg and a battery of 12s6p 30qp
Here’s a basic layout without the cablesGood to know. My hopes are high.
6mm2 so basically very big wire XD cause I’ll double each wire
Also is there any issue with 50cm canbus wires? You guys are truly helpful!
I steer away from canbus in my opinion don’t like the fact that if one vesc dies u have another perfectly fine vesc that is useless if it happens while riding. I always use ppm y splitters, with my 4wd it was a no brainer that ppy y splitter for 4 vesc far away from each other was impossible to do I did 2 receivers and 2 ppm y splitters but I have then switched to 4 receivers one per vesc for more redundancy.
Hi everyone,
I’ve recently received my Unity and I’ve been trying to get everything set up for the past few weeks, but I keep running into the same error and haven’t found a solution. When running the motor detection I keep getting the error “L is 0. Please measure it first.” Has anyone had a similar issue or know of a solution? Any help would be greatly appreciated. I’ve been working on this project for more than six months and am desperate to get out and ride.
