Spent some time looking around taobao for esk8 stuff, thought I’d share my findings. Have you guys found any interesting esk8 stuff on taobao? Please share your findings if you have!
Dual motor kit - $130 USD
I know the mounting system has problems, can be solved by drilling holes into trucks then threading the hole with same size as the screw in the mounting plate then screwing straight into truck.
https://world.taobao.com/item/548193712139.htm?fromSite=main&spm=a312a.7700824.w4002-13745567663.51.3U9dp5
Dual mounting kit - $72 USD @Baz_L used this in his build Same mounting issue as above, mounting plate will slip if you don’t put a hole into the truck, easily solved.
https://world.taobao.com/item/528942351980.htm?fromSite=main&spm=a312a.7700824.w4002-13745567663.109.LYhqbtLots of other interesting stuff on the BOX taobao store https://shop113010081.world.taobao.com/search.htm?spm=a312a.7700824.0.0.awT9UP&search=y
I’m sure we’re all familiar with the name MayTech by now, $76 USD VESC https://world.taobao.com/item/536720652464.htm?fromSite=main&spm=a312a.7700824.w4002-10533265171.31.TfybWN
Maytech store has a few other ESC and lots of motor options. https://shop117792249.world.taobao.com/search.htm?spm=a312a.7700824.0.0.CGnqtm&search=y
Enclosure - $15
https://world.taobao.com/item/539739329937.htm?spm=a312a.7728556.201601086188259.5.QXguJR&scm=1007.12679.24488.539739329937Bamboo decks
https://shop110785955.world.taobao.com/search.htm?spm=a312a.7700824.w5002-7129424980.1.P0aM4n&search=yCrazy spring loaded truck risers - $23 USD
https://world.taobao.com/item/527497009307.htm?spm=a312a.7728556.2015080705.14.M4fSJw&id=527497009307&scm=1007.12006.72291.i41445447322&pvid=d3dfaf1d-7f8b-40ed-8009-a69fdcc8a848Springy MTB trucks - $50 USD for front and back
https://world.taobao.com/item/542041900411.htm?fromSite=main&spm=a312a.7700824.w4004-9375755746.26.OcFF9KTruck screw cover plate - $4 USD
https://world.taobao.com/item/543648153453.htm?fromSite=main&spm=a312a.7700824.w4002-3053938045.50.Py45huMaple 7 layer Penny / Nickel deck - $5 USD
https://world.tmall.com/item/545781594610.htm?spm=a312a.7700718.1998025129.1.znEPaz&abtest=_AB-LR32-PR32&pvid=320b20ca-069f-4986-b752-05bef698e6cf&pos=1&abbucket=_AB-M32_B18&acm=03054.1003.1.1539344&id=545781594610&scm=1007.12144.81309.23864_0
Battery meters - around $4 - $5 https://world.taobao.com/search/search.htm?_ksTS=1496358143983_306&spm=a21bp.7806943.20151106.1&search_type=0&_input_charset=utf-8&navigator=all&json=on&q=电瓶蓄电池%20锂电池%20电量显示器&cna=UJuqEW70WSYCAU9DscFwBrNv&callback=__jsonp_cb&abtest=_AB-LR517-LR854-LR895-PR517-PR854-PR895
A few stores, you can go through their inventory by clicking page 1234 at the bottom of the page https://shop103867016.world.taobao.com/?spm=a312a.7728556.2015080705.3.8QQ0X2 https://shop109652967.world.taobao.com/search.htm?spm=a312a.7700824.0.0.OcFF9K&search=y https://shop129341467.world.taobao.com/search.htm?spm=a312a.7700824.0.0.03p1BZ&search=y https://shop162656815.world.taobao.com/search.htm?spm=a312a.7700824.0.0.RB03Fj&search=y https://xiaoyuban.world.taobao.com/search.htm?spm=a312a.7700824.0.0.8hwv68&search=y https://yibaoyd.world.tmall.com/search.htm?spm=a312a.7700824.0.0.sPc6ms&search=y https://dchong.world.tmall.com/search.htm?spm=a312a.7700718.0.0.8XXfop&search=y
