I’m a first time builder and I just finished my first board. It works properly after some troubleshooting for the enertion nano-x’s binding issue, but one problem still remains.
At times, when I press the throttle, it doesn’t immediately go. Sometimes there’s delay and then the motor instantly jumps to the highest speed. The brakes have the same problem; sometimes they don’t initiate, and then they slam all at once.
This is becoming a major problem, and I’m not sure where to begin troubleshooting. Is it something mechanical, like my belt, or is this something else?
I’ve had that issue before. With my build is was the receiver. You should start by moving the rever away from the other components on your build, Then try a different remote/receiver. Doing that will either confirm/ or rule out the problem. Then move to your Speed controllers and programming.
