Looking really good. Those were the wheels from France?
They sure are.It took a few emails to sort but there not to bad to deal with.Ride on
wired and testing bms i only charging to 41.9v need to look at each battery
1 battery not holding charge hk dont have a replacement in stock had to buy 5 new batterysMy wife told me i dont have time for this build …hate to say it she was right
Over 360 shamrocks and i need more
Test run today very happy,I forgot my helmet so i took it easy going well at 40.7km smooth power getting there no sag at all the 5x2s 5000 setup thanks to Namasaki is great ill test run tomorrow see what the max speed will be if i get 46-48 km ill be happy…I just need to sort my bms its on order
How did you paint the motor? Did you take it apart?
I used Frog tape and then primed it with etch primer then 2 coats of of green spray
would i colour code every thing again no
Blew my vesc so gave me tome to gett a bit more work done
Switch and charging port done besteck bms done Scratched the griptape with the drimmel
10 steps forward 3 steps back…
How did you blow your Vesc?
Only thing i done was changed to foc went out on a run done 10 miles felt great like there was no board under my feet…like i was floating on air Went home charged up next day wentbto go out motor not spinning drv chip error…sent it off to be fixed…i have a focbox on the way as well
FOC, Silent but Deadly
I know i wont be doing it again.
What brand of Vesc where your running? Seems that some brands are not able to run FOC while others are.
really nice lookin board comin from a fellow irishman.how ju find the offroad wheels vs the abecs for irish road bud
