I see a lot of 10s2-3p packs being used on an electric skateboard. But isn’t that …p ratio not a little bit to low?
What I would think is that 2 or 3 18650’s in parallel, so 4.4 to 6.6Amps, are a bit low range.
Pls explain me were I am wrong. Or where I can find information about it, I couldn’t find it
Okay, so they can deliver the max amps needed, but still can a board drive for a decent time with only a few in parallel? are the much batteries in series compensating for it?
theres tons of complete boards sold with very few cells that aren’t even high discharge but they suck and then they die quickly. I think there’s even some higher discharge than 30 amp cells these days. or better yet just get some lipo
Depends on multiple factors but the general rule of thumb is that bigger is always better.
It’s always best to have some headroom so that your battery is not over stressed.
My advice is to build more battery than you think you’ll need.
Oh yes guys thank you! Idk what I was thinking but I will buy the standard 25c 5000mAh 3s lipo’s for my board, and they have 5000mAh… this wasnt my brightest moment.
