Continuing the discussion from Tacon 245kv mono drive and 10s4p… Will it work?:
Is 245kv with a 6s4p setup of 18650s a good idea with the 6S ESC?
Yes, usually, any motor is fine.
What is the mAh and C rating of the batteries?
Max. continuous discharge current: 20A Safe pulse discharge ratings: 95A < 0.5 sec, 65A < 1 sec, 40A < 5 sec, 30A < 6 sec Nominal capacity: 2500 mAh
Looks solid. At 6s4p with a 245kv you’ll be fine so long as the esc is also rated at least 90A.
