It seems most people believe that the GT given it’s size and weight will not be able to make it ~30 miles on a charge. After this picture surfaced:
One person (@evoheyax) speculated that the battery might be similar to the Raptor’s:
Let’s assume the picture above is a 10s4p set up. To my understanding, if the Raptors (that get the 10s4p battery) can go ~24.8 miles on a charge (in ideal conditions, going top speed most of the time) why is it not possible for the Evolve GT to get more range if 1) the torque is less powerful 2) the top speed with 83mm wheels is 22mph (vs the Raptor at ~28mph) or 3) the test for max range with the GT was conducted in an eco mode (where the top speed is limited to around 16mph).
The board is less powerful than the raptor and has several different modes that can limit the power used. Maybe some of you can enlighten me on why getting that range would not work. Thanks guys.
Edit: **** No one knows what the Wh is for the battery, which is what is causing most of the doubt. *******
