I am currently using this pack but more as a spare pack because i have to be careful with it…
i can charge it with a balance charger and it will balance it but when i ride hard it will drift very fast…
You got me wrong!
I have no BMS yet but i am a huge fan of a BMS because it is protecting the cells!
<br
That is not a draw back! It is a huge advantage over a balance charger.
I do agree!
Why? Could you explain it a bit further?
Hi, I need some help. Do you know anywhere I can get a good BMS. My setup is a 10S (2x 5000mah 5S lipos). I want it for charging. I dont know how discharging helps because I assume that the cells are discharged when you ride the board right? Of course I dont want to spend a lot…
Thanks
maybe you could unsolder it and ride with a cell less or add a replacement cell. i have a couple laying around.
One less is a draw back but a possibility. Replacing is only valid if the IR is the same or it will get unbalanced soon again.
