I use an iMax b6 6A 80W charger to charge my two 8000mAh 30C 3s batteries in parallel using a parallel charging board. I was wondering about the fast charge option on the charger. Normally I charge at 6A but I think that takes 8 hours to charge…
My question is if fast charging is putting my batteries at a risk. I understand that fast charging doesn’t balance charge them, but I could use one of those balancer things to balance them after I think, and balance charger when I don’t need fast charging. Also, how much faster would fast charging be. Would it even be worth it?
