For my personal review: yes, it is. Definitely important.
Here’s why:
Less rolling resistance, more efficient drive system
With a drive like belts, you have to counteract the belts friction and the tension applied to the belt before the board can get rolling. Since it takes more force to get it moving, you have a loss of efficiency so your power and range take a direct hit. With a gear drive, there’s very little resistance because it’s simply one gear directly attached to a motor enmeshed and acting against another gear without tension.
upload from https://www.instagram.com/eovanboards/
Are there any other points you can list about gear drive?
Eovan GTO SILO will be launched today and now you know the biggest updated point of it!
