It is bad for the battery or any of the other electrical components?
âdeadâ doesnât mean anything. Are you referring to 0.0 volts per cell? If so, then yes. Also, only if itâs a lithium-based chemistry. What chemistry battery?
To expand on b264 - Typically ESCs and VESCs have âcut offâ limits for your battery. Basically each battery cell holds appx 4.2v and when it âdiesâ when connected to a vesc you can set it to die at 3.2v (or something around there) - so technically the battery still has juice in them but it is there to not destroy/ruin the battery. This is what many here will tell you to set it at at least. If you set your VESC and put it at 0.0v, then yes, you will harm the battery.
I also apologize if I am a bit off on the electric numbers, I am not currently in the eskate world, just got out last year and contemplating building again!
I didnât put cutoff numbers on purpose because different chemistries have different ones. If you used LiFePO4 cutoffs for li-ion, for example, you will damage the cells. So those numbers above are examples only.
Can anyone tell me what the cut off should be for Samsung 30Qs?
I have mine cutoff to start att 33v and ned at 30v
Absolute low is 2.5 per cell. What I use: 2.8 per cell. What most use: 3.0 per cell.
Thatâs for 10S. So for 30Q cells thatâd be 3.3V or 3.4V start and 3.0V or 2.8V end per cell. So for 10S, multiply by ten and for 11S multiply by elevenâŚ
On a side note⌠whatâs a good start and end cutoff for a 12s3p 30Q pack
Take those values multiply by the # of S in your pack
I have no idea why I left that part out Yup thatâs for 10s
What is the logic here behind the cut off calculation? Why is it more or less depending on series?
Cutoff keeps the ESC from over discharging your pack (this can damage the batteries). A 10S pack will have a voltage range of 30 to 42 Volts (10 * 3.0 to 10 * 4.2). Basically total battery voltage is dependent on how many cells are in series (xS*V_batt where x is the # of cells in series). Putting two batteries in parallel just increases the capacity, not the voltage. Think of two square blocks. You can put them on top of each other making a block twice as tall (2x voltage) or next to each other for a wider block with the same height (2x capacity). You cannot increase both without more cells. To double voltage and capacity you need four times the batteries. I hope that makes sense.
Edit: capacity in mAh; capacity in Wh will increase both ways (mAh * voltage).
Thanks this idiot did not realize that each individual cell would be lower voltage with more cells in series if you kept the cutoff the same as with lower cells in series.
30/10=3.0 30/12=2.5
So to still be in the safe range I could go with 34 volts cutoff at the least I would say for 12s. 34/12=2.83
Lithium ion cells have basically no juice left in them below 3V anyways. 2.8V while technically safe will not gain you anything and may shorten your batteryâs life. I would use 3V per cell as a safe cutoff. You can go lower, just know that you donât gain much.
Setting your cutoff at 2.8V will probably get you ten meters more range than setting it at 3.0V
For sag reasons though 2.8 would be preferred.
