I recently ordered a 12s 8A(now I feel like I exaggerated on the Amps) charger for a 12s4p battery from Aliexpress with a 5.5x2.1mm plug, now I’m having a bad time finding a female connector for it that I can know for sure will handle 50.4V @ 8A.
I don’t feel like using GX16, XLR, XT30 and etc. So I’m wondering: Does anyone know if I can modify the charger to output 5A instead of 8A?
I should just take a look inside.
They have 4 versions starting from 6.5A so maybe these 4 chargers are just the same only a little adjustment on a potentiometer inside makes the current change.
If you can’t adjust it, there’s a nasty way where you get a step up and step down converter to regulate it to the (usually 3) amps of the converters. Word of caution is it will get REALLY hot
Charger just arrived today. It has 2 adjustable knobs inside, I assume one is for voltage and the other current but I don’t know nearly enough to be confident. What do you guys think?
