So this past Monday I decided to ride my Raptor through wet and salt filled streets to and from work. I didn’t notice any problems riding either way. I wiped the board down thoroughly after each ride. The following afternoon I took the board outside and neither of the motors moved. I quickly brought it back inside my house to dry it off again and try to run the motors without any load on them. Only one would spin very slowly and the other didn’t spin at all. I powered it off, opened the battery lid and powered it on again. I heard a little pop noise from one FOCBOX, then starting smoking a bit, so I quickly powered off again. I’ve since been hesitant to power it on again not wanting to potentially fry my other FOCBOX.
Did I really just FOC-up my FOCBOXs riding in the shitty weather? What should I check or try next to correct the problem? Any help is greatly appreciated.
Can you freely turn the motors/ wheels with your hand? Also remove the plastic cover from the FOCBOX you believe is fried and post pictures of it here if you can
One motor has resistance at a certain point of a 360 rotation, which is the one connected to the fried FOC’dBOX. I’ll post pictures later tonight when I get home from work with the case removed.
Sorry for the late reply, I’ve been at work all day. Those FETs are in rough shape. If you have rubbing alcohol on hand, use that and a very very soft toothbrush to remove the corrosion and salt from the board.
Yep… it’s the winter season, bois. If your city is known for salting the roads during this kind of weather, then you better start investing in some Silicone sealant and waterproof enclosures for your electronics.
That’s the thing, the opening where motor wires pass through the deck was completely sealed with silicone sealant. However, I’m thinking that some salt water may have leaked through the upper battery lid and pooled into the rear of the enclosure where the FOCBOXs sit. FML
