I think that I’ve got the right idea on the wiring layout, but before I hook it all up I want to double check I have it correct.
I’m going for 2 4S 10,000mAh batteries connected together to provide 8S 10,000mAH. I’ve got a loop key for safety and a single charging point with a 8s balance system.
I’ve got one batteries positive into the other batteries negative and then the other pos and neg provide the power.
Any help or corrections will be greatly appreciated.
So if I’m understanding this correctly the loop turns the system completely on or off and the pwr is the charger input. With this wiring setup you’d need the loop key in to charge and so the VESC (and motor and receiver) would be powered whenever you’re charging, which if that’s what you wanted is fine. Just to be aware
What’s the switch doing? And are you using an external balance charger or an internal BMS?
I wouldn’t say it’s a “bad thing”, I just probably wouldn’t do it
As in I don’t think it will cause damage to any components, but it could create interesting situations like where you accidentally bump the remote while it’s charging and it takes off across the room (and then possibly breaks something, itself or otherwise). My philosophy is only have it on when you’re actively using it and paying attention to it. We build these boards with a lot of power and they can cause some serious damage if we’re not paying attention to them.
