As long as it’s below 280kv / 260kv, should be fine. Some uses 190kv or lower, but I think 213 is not much different than 190kv. Abit less torque but abit more speed. If you use belt drive config it should be very fine.
That’s a fine motor.
You can use any kv motor if u adjust the voltage or gear ratio. But if you use lower voltage it’s harder to push the amps and get to a high power.
Thanks for the answer. Any idea about how much range I will get and max speed with this motor and a 36t wheel gear and 14t motor pulley? Also I am using 75mm wheels.
According to this calculator, you should hit about 20mph @ 38.5 volts. If you jump up to a 16 tooth pulley with 83mm wheels, or just jump up to 97mm wheels alone, you should be able to hit 25mph.
I didnt flatten the shaft because i never feel like doing it. what i do to ensure it doesnt slip is to swap out the small grub screw with a bolt of the same thread cut. Usually M3. and i use thread lock and it doesnt dare move!
Definitely flatten the shaft with a dremel or hand file where the set screw will go. It only takes 5 minutes and you’ll really regret not doing it if the motor pulley breaks free. And still use locktite.
Dang ok. I guess it would be dangerous. Thanks for clearing that up. If I don’t but this Turnigy, I guess I might aswell get a DIY motor that actually has a key and matching motor pulleys with key shafts.
Hello,
I’m new here and have a question. I bought the turnigy 6364 190kv and the hk 150a esc
I tried it with a 3s 5000mah battery but the motor don’t move. Once there was a little spin but that’s all. Can somebody help me? Why don’t the motor work? What’s the problem?
Thank you
