Ok, so I have an 8S setup, with SK3 6374 190 KV, and the esc is an FVT “sleeping lion” 12s esc.
My problem is, that since I am on a penny style board, the torque is way to much. Even on the lowest setting, that is availabe on the programming card.
I guess this is kind of a weird case… People usually have less torque than they need, not more.
What’s your top speed because you could change your gearing or get bigger wheels and it would go faster with less tork but at a point it’s to weak to make it up his
Well, I am running 97mm wheels, so I don’t want to go higher, also, my speed is 36 km/h, which is scary on a small board like this. (So thanks, but no more speed for me… )
I am looking for an option with no money spent.
Is there a way to access the settings directly, and instead of selecting “slow”, you write in a number?
You could probably add something to regulate the exseloration or if it came down to it change escs
If you did deside to change your gearing you don’t have to use all the speed my setup I went 38mph witch is about 61kph but it didn’t have enuff tork for hills so I had to down size wheels
You can try trimming 2s off the voltage but I’m guessing that your running a couple 4s lipos so going to 6s would mean new batteries and may still not give the results your wanting.
I believe upgrading to a vesc would be the easiest way to achieve smooth controllable power along with smooth controllable and predictable brakes.
Either way your probably not gonna solve this without spending money.
Under resoldering, do you mean that maybe I have bad connections?
Or do you mean that I should make a 6s pack?
@Namasaki is right. I have 2 4s packs in series.
Make a parallel 4s and see how it goes. 1/2 speed and torque. Keep the range. Sounds like you need a control compromise between gear and amp. I ride a car ESC board making 5600watt, (7.5hp), it has enough torque to rip off a 300lb gorilla. It took some time to get used to the torque. Maby just exercise some throttle control! Good luck with your build
I would go to 83mm wheels in a penny, and use a 40 tooth wheel pulley. There are numerous places you can download wheel pulley models and 3d print them.
