Packs in series add up voltage and the number before the s
Packs in parallel add capacity and c rating and the number before the p
So two 6s packs in series equals a 12s pack
And that bms is for 6s not 12s
So, no
Are you after a 6s setup or a 12s setup?
If you are using only one of those batteries at a time, yes. 6s bms will work with a 6s battery. If you put them in series, like @krloz said, you get 12s. In that case it’ll not work and you will need a 12s bms.
Also, the max discharge is 10a, unless you want to bypass the bms for discharging, that’s too low.
It depends if you are planning on going above 60 BATTERY amps for more than quick bursts. Then if you are using the bms for discharge it will reboot your esc And that is bad.
You got 16 Ah 12S battery, and motor with peak current of 80A.
If you plan to use VESC with this setup (you probably are since 12S is 50V), you can always set the limit to current from battery in vesc setup.
Just put battery max value in the safe mode at around 40 (40A), and motor max to your motor value: 80A
And 40A for the battery max, since vesc, at least 4.12 hardware one, cant handle more than 35-40A continous current, before going nuclear.
About BMS. For your motor type, it would be best to get BMS 12S, with 80A discharge and 10A charge.
I recently made 2 e-skates, with the same type of battery/ capacity, (but 2x4S), and i use 8-20S BMS. 80A discharge/10A charge
This bms can go with 8S as well as 20S. i use it with 8S, 33,6V at it works perfectly. It’s BMS i bought in some e-bike store in my country.
I have twin vesc’s, and two motor 6364 outrunner 245 kV,. Each motor is rated for 70A.
I setuped each vesc with: 70A - motor max, and 40A battery max, and it works great, nothing overheating, nothing shuts down.
Here is the link to my build thread. Maybe it will help you.
