Could anyone give a comment if this BMS would work with mij 12S3P lipo’s?
It says it’s a li-ion BMS, would it work safely with my lipo’s? I will only use it for charging and not for discharging.
If you are only using it for charging you could get a 12s 5/10/20a BMS. It will be cheaper and you don’t have to use the BMS for discharging, so the amperage won’t matter.
I just haven’t found those on aliexpress. Only for 12S 36V battery’s… Not for 50.4 volt charging.
Well the 40a one will work, but if you can find a lower amp you may be able to save some money
