I don’t think the switch is bad/faulty because once I connect the pack to the ESC’s. Not even the ESC’s will turn on.
did you connect the e switch
Nothing is connected to the e-switch on the BMS. should there be two switches?
These wires are loose
The bms e-switch is not optional
How or where do I connect these wires?
connect them to a 2 pole 12v automotive on/off switch use that switch to turn the bms on/off and to reset it from protection shut down.
So I will have two on/off switches one for the BMS, and one for the anti-spark switch? That doesnt seem right?
you can put a rocker type switch like @Namasaki uses, or bypass by wiring together because you have an external one. the bms has a reset function time-delayed if it is tripped so the options are to have the function on/ off with switch or always on wired together. if you just spent 60$ on a luna switch use it
You don’t need an external anti-spark switch with this bms.
no one said you did, but he bought one for the pretty led light
Lol, well I already spent $60 bucks on it. So could I simply just solder the BMS on/off switch? and rely on the anti-spark for my on/off.
It’s is possible to have a lighted switch with the built in E-switch.
The problem with external E-switches is they are prone to failure from excessive heat cause by the high current passing through them.
if you use a pushbutton latching 5pin and supply power for led off esc
If I was in your shoes, I would sell it and use the one in the bms.
true for the old style 2-4 mosfet anti spark switches. the biggest problem was finding fuses now they are coming along with improvements
I’ll probably sell it then.
But I’m still confused. Can I simply put a two pole, on/off switch to connect the BMS e-switch?
Yes, just a 12v 2 pole on/off switch. You can get them at the local auto parts store on online.
yes, that will do
Well sick. Thanks guys.
I also bought a battery capacity tester to measure voltage, Correct me if I’m wrong, but I could connect that anywhere in the hot wires leaving to the ESC? https://www.amazon.com/gp/product/B01LQ7MT4K/ref=oh_aui_detailpage_o01_s00?ie=UTF8&psc=1
yes anywhere past the e switch because that’s an a always-on led
