I wonder if this BMS and CHARGER is safe to use. I’m thinking since it is so cheap. I will just be using it to charge.
15 amps is very low. Do you plan to bypass? Cheap stuff is usually not reliable The charger is fine. I have that one. So far so good.
Yes. I will bypass. I will just be using it to charge… Link to any good 6s bms?
Is this Bms too cheap maybe? Or will it be okay?
If you plan to bypass no need to buy an expensive one. I can vouch for the charger but i dunno about that bms. Wait for a second opinion.
Thank you for that info. So, nobody have tried that BMS?
