Is this the typical DRV failure?
I have a problem with a board with a 4.12 vesc from esk8.de With newest vesc tool, motor detection fails… I got this from the terminal
Is my DRV dead ?? The voltage reading seems to be right (6s board)
FAULT_CODE_NONE
The following faults were registered since start:
Fault : FAULT_CODE_DRV Current : -0.2 Current filtered : -0.6 Voltage : 24.69 Duty : 0.008 RPM : 0.1 Tacho : 4 Cycles running : 2 TIM duty : 412 TIM val samp : 206 TIM current samp : 25668 TIM top : 50924 Comm step : 4 Temperature : 28.91
Fault : FAULT_CODE_DRV Current : 1.1 Current filtered : 0.2 Voltage : 24.69 Duty : 0.008 RPM : 3.5 Tacho : 7 Cycles running : 2 TIM duty : 412 TIM val samp : 206 TIM current samp : 25668 TIM top : 50924 Comm step : 1 Temperature : 28.94
Fault : FAULT_CODE_DRV Current : -1.2 Current filtered : -0.4 Voltage : 24.72 Duty : 0.008 RPM : 3.6 Tacho : 10 Cycles running : 1 TIM duty : 412 TIM val samp : 206 TIM current samp : 25668 TIM top : 50924 Comm step : 4 Temperature : 28.97
Fault : FAULT_CODE_DRV Current : 0.3 Current filtered : -0.1 Voltage : 24.72 Duty : 0.008 RPM : 0.1 Tacho : 13 Cycles running : 1 TIM duty : 412 TIM val samp : 206 TIM current samp : 25668 TIM top : 50924 Comm step : 1 Temperature : 29.02
Fault : FAULT_CODE_DRV Current : 0.0 Current filtered : -0.2 Voltage : 24.70 Duty : 0.008 RPM : 4.3 Tacho : 16 Cycles running : 2 TIM duty : 412 TIM val samp : 206 TIM current samp : 25668 TIM top : 50924 Comm step : 4 Temperature : 28.86
Fault : FAULT_CODE_DRV Current : 1.1 Current filtered : 0.5 Voltage : 24.70 Duty : 0.008 RPM : 3.5 Tacho : 16 Cycles running : 1 TIM duty : 412 TIM val samp : 206 TIM current samp : 25668 TIM top : 50924 Comm step : 6 Temperature : 29.04
Im afraid so, you need to replace the vesc or the DRV chip
maybe telling us what you have done with it could led to some informations.
The vesc is just blinking when i push the throttle… and motor detection fails
