I finally received my space cell, so time to move forward. I soldered wires between the vesc’s as specified by @onloop. my setting changes are as follows:
master: id 0
slave: id: 1, enable multi esc over can, enable send status over can
only master vescs motor spins…
This could be related to the masters servo outputting 3.2 volts instead of 5, but I want to see if there’s anything else I could be doing wrong. Thank you.
My advice with Dual VESC, set the BLDC tool up identical on both VESC. all settings the same. Then simply enable send status over can & multiple ESC over CAN & make sure they have different ID’s
I double checked all settings, changed the no app to ppm, and they are now the same seting wise besides the sends status over can and enable ESC of can. Same behavior.
What are the pulsewidths you’re getting when you click “display” and go to full throttle and full brake ? You can read them in the display box next to the moving blue bar.
And what is the blue bar doing ?
One works fine, the other has an issue with the servo power pin supplying 3.2 volts instead of 5. I bought both of them from you and this is my first time using them. Powering them with a regulated power supply.
@trbt555 Its hard to check them because it goes straight to full speed when I hit the brakes. Looking at the bar, I need to adjust the values a bit, as it goes full blue before I hit full throttle, but goes less then half way when I hit the brakes. So it need to adjust them, but I can’t imagine that causing any problems. My other controller was working with the one vesc that was working, but is now not working at all. (pulse bar does not move, despite receiver lighting up)
