Thanks to the helpful people on this forum I was able to build my own e-skate last year and it was a perfect success. I love it and I ride it whenever I can. Still I am not completely satisfied and I would like to make an upgrade.
My build:
5 LiPo 2S 5000mah 40C batteries from Turnigy
10S BMS from Bestech
Maytech VESC from APS
APS 200kv 6374 Motor
motor mount from [APS](https://alienpowersystem.com/shop/cnc-kit/alien-drive-complete-kits/alien-drive-systems-electric-longboard-diy-kit-50mm-motor/)
Orangtang 80mm wheels
My Issues:
One of my main problems is that whenever I accelerate the percentage on my battery indicator drops to arround 50-60% and stays there when I keep going fullspeed. Once I stop the battery indicator goes back to 99% immediatly after a short ride. The problem with this that whenever I drive a longer distance my board will stop because it reaches the cutoff point, whlie riding even though there is more than 50% of my battery left. So effectivly I am only getting 50% of my boards capacity and I don’t fully understand why. Of course I could set my cutoff voltage even lower, but thats not a good solution either I think. Why does the Battery level drop so quickly when accelerating and riding fast, but then goes back to where it was on stand still? Can Improve this with higher quality batteries? Does it have to do with the C Rating? PS: I am not sure if this issue has always been there. I rememer that I used to get arround 14-18km out of my board. That seems impossible now. After 8km riding fast an continously the battery level (while riding ist too low. If I stop for a min and check it again there is still more than 40% left.
I have one motor. I am about 90kg heavy and my motor has enough power to get me almost everywhere I want to go. My main issue is that when I go into a right curve (especially with tight ones) all the weight will be distributed on the other side of board, instead of where the motor is, which means I can’t accelerate in curve. The wheel will just spin through because there is no traction. Most of the time thats not a big deal, but if its an upwards going curve you loose all your momentum and that can be really annoying OR you can’t brake when going downhill. So I will upgrade to a second motor. The motor I have right now has suffered a lot already and I will exchange it for 2 smaller 200Kv ones I think. Also does it matter if the two vescs are not from the same brand?
Batterycapacity in general is not good enough for me anymore. I don’t want to buy a new BMS and I love the slim formfactor of my build. 2S Batteries are perfect for that. I was thinking in buying a new deck and mounting the motors backwards. I think with that I will be able to fit another 5 2s 5000mAh Batteries under my deck without compromising my slim fromfactor. At one point it would be a little thicker, because I would have to stack the vesc and bms ontop of the batteries, but thats worth it. That would give me 10S2P and would be a significant improvement. Does anyone else have other Ideas for improving my battery capacity? PS: For now I would like to stick to Lipos.
The wheels are simply too small. 80mm in a city with tram rails and cracks is critical. Most of the time I have no trouble going over them, but its a hassle and really uncomfortable to drive with. Now I don’t want huge offroad wheels, because I would have to change my entire mounting for that. I want to do an upgrade, not bulid a new board. I found these wheels. That would be a size improvement of 20mm. Do guys think that will make a big difference? It might, but I’m not sure about it. Do you guys know any other bigger longboard wheels and am I right that I could mount those wheels with my current mount from APS? I also just found out about these.
It’s time to get back to buisness. I see I missed a lot of new stuff while trying out my first board. I’m excited to get building again. Thanks for the advice in advance guys.
