I have the exact same setup! Except that I have a DIY fiberglass enclosure that is not comparable with yours
12s3p battery works great on this tiny board, plenty of power. I hope you will have fun!
Edit: I am also interested in knowing where did you find a 12s mini BMS
Somebody mentioned that you can add a balance board to it, but in my humble opinion that will be also not smaller than a d140.
But what you can make, you bought the d606 which can balance. In case the balance plug is the same you could use this bms from time to time to balance out your pack externally.
The d503 will take care that you don’t over charge your cells. So you could use that one for overcharge safety and every 10-20th charge cycles you will change the balance plug to the d606.
Hmmm @Hummie mentioned using two of these a while back. Maybe I could make some enclosure ports for the connectors and use these when I charge. Any thoughts?
I like that little one. I have one. If u order them get me two more and I’ll come give u cash! N a cookie.
It’s very slow to balance but works. Best if you wire up all your pack into two 6s plugs for them. I mostly just use one though
