Wtf? I thought I was at last finished and then boom, wheels spinning in opposite directions.
Help? Why?
Help? Why?
Turn off the board, swap 2 phase wires on the motor spinning in the wrong direction.
There’s 3 wires; a, b, and c. Which 2?
any 2
10char
any 2 of them
After swapping two of the wires didn´t you need to do a motor detection again if running FOC?
Yup wheels not spinning, guess I’ll run vesc tool again
sensored? I guess yes.
Thats weird
Yes i rcalled it correctly, if running BLDC you just can swap wires around in Foc you need to recalibrate.
Yes- run motor detection again after swapping the wires. Be sure to secure the tightly w tape or heat shrink. You don’t want them disconnecting during a ride!
I swapped, ran motor detection, and still spinning wrong direction… ?
Ugh…
So it’s spinning the right direction during the motor setup test phase, but as soon as I finish with the remote ppm input setup wizard it spins the wrong direction…
Any ideas?
EDIT: found it. GREAT SUCCESS!!!
Ok I found “invert motor direction” under the general tab in motor settings but I don’t see an “apply” button anywhere.
Anyone know where the “write motor configuration” button would be?
On the right hand side of the vesc tool it´s the M with arrow down. Just hover over it and the symbol will say what it does.
