Do you need all of them? I would be very down to trade some for lightly used LG 18650 cells 3200 mah
(spec sheet)
(spec sheet)
They are way too low amps for my specs(10amps) , it would take 10p to get up to 100 amps. But they have quit good mah
What makes you think they are only rated for 10A cont?
I looked at the specs sheet
What spec sheet u looking at, bro.
Trick question, it’s the wrong one.
30A continuous for the m1a cells (the ones you got). ~$17 more would have gotten you the m1b cells they have listed which are rated to 50A cont. Real world values may be a bit lower, but it ain’t no 10.
I am still waiting for my pure nickel strip and diy spot welding machine (on transition from china ) i will upgrade all the specs from the battery and send a data sheet
Finally manage to configure all pack before welding , pack will be 15s6p or 16s6p(a bit overkill and the last cell is a little bit in voltage i dont dare to use it , about 0.4 v difference)
Its should fit perfectly under a longboard for a good slim look
20cm large and 78cm long
Get a redember 44 (it’s a deck). Those things are massive, would certainly be a little more easy to fit a pack that gigantic
