https://hobbyking.com/en_us/kd-53-30-high-voltage-brushless-outrunner-190kv.html
10s with 14:27 gearing.
Any reason why this is not going to be a beast?
Thoughts?
Thoughts?
Iv never seen a 27t wheel pully.
Chain driven
Are you planning on using one or two of those motors? Battery specs?
I have a board exactly like this. Same motor and gearing on 83mm wheels. It uses an eBay esc. The acceleration and brakes suck.
It’s being upgraded to a 10t sprocket for more torque and probably a vesc soon too
After much deliberation I am going to see how it goes single motor
@SJG717 These batteries x5
I am open to using an sk3 or sk8 if that may be better
@Jmding the gearing is a bit weird it just what comes with the pack i could always change the ratio later
Make sure to use a vesc. It is not much more cost wise and opens up so many more options
Yeah still deciding between Flipsky or HK vesc but I’m definitely going to use one.
Hobbyking is probs the better choice because of the 1 yr warranty but it is a little more
true 1 year is decent to be honest worth the little bit extra
Edit: Not sure of these figures
This is on a 17.5 inch wheelbase board.
I think that should be reasonable. The main influence on torque output is motor amps. That why my board with this is so low on acceleration because the eBay esc is only rated for about 20a
Hk vesc s are a nice strong unit and both sk3 and sk8 are great motors. Depends whether you want sensors is all. The warranty though well that is in another league to any other vendor. They are so big they can afford to be pretty flexible with returns. Half the time they don’t even want the defective shit back. They’ll give you the opportunity to open it up and look in the case of motors and take pics etc.
It’ll probably have enough torque to go up a 2.5% grade hill
Erm, if you are gonna use the 100mm wheels you will need to change the gear ratio. It will be stressing the motor at that gearing. I’d search eBay for 6.35mm roller chain and find a 11 or 12t sprocket to swap it with. I swapped to a 10t on my 12s board and still hit 60km/h
Yes, with current gearing and 100mm wheels. With a 10t it will be very powerful
found a 9t not a 10t yet
