Can anyone supply me with the dimensions, please? I’m trying to work out if I will be able to fit them in dual configuration on my trucks. Are they a decent motor? has anyone fitted hall sensors?
Thanks, Shaun.
Thanks, Shaun.
Just check on their page lol
I checked with HK but they can’t even confirm the dimensions lol
I can when I get home if someone else doesn’t beat me to it.
Two won’t fit on calibers
Ok. I’m using e-calibers so have a little more room. Would you mind measuring the can from the front face to back of the bearing?
It’s 66mm
Dani
Lenght is exactly 65,50mm.
I have already told you in your last topic, you can fit two on e-caliber, even with 15mm belts.
Thank you.
Go easy, I’m in a pickle with these motors haha!
Pulled the trigger on two of these.
Update 10 char
ran mine for about a week and it shorted. At 70a on a 10s5p
What shorted and where?
I’ve been running mine for 600kms
And I got it second hand quite beat up already. These are rock solid
Not sure something wad wromg with the wrap . i took the motor apart and noticed random solder in between the wrap thats only on that one. I think ot was just a fluke.
